Header Vibrating Agaist K-Member - Suggestions?
Old Aug 14, 2004 | 09:57 AM
)2overt SS's Avatar
The only thing I can think of is header wrap.. but I want to try and avoid that because I've heard it can be a fire hazard etc... It's just the passenger side that does it. I have enough rattles as it is.. I don't need to feel the header through the floor
Thanks!
Old Aug 14, 2004 | 10:37 AM
turbo_Z's Avatar
Re: Header Vibrating Agaist K-Member - Suggestions?
try new motor mounts.
Old Aug 15, 2004 | 08:58 AM
)2overt SS's Avatar
I'd rather try new motor mounts as a last resort.. I don't want to spend all the effort and have it not fix the problem.
I can't seem to think of anything besides header wrap that wont melt or burn...
Old Aug 15, 2004 | 09:22 AM
oldBones's Avatar
Talking Re: Header Vibrating Agaist K-Member - Suggestions?
My jet hots had that problem. Put a jack under the motor and unbolt the passenger side motor mount and lift the motor and then take a (Little) bit of metal out with a die grinder at the k-member. You may need to drop the k-member a little also. Before you tighten the motor mount bolt; raise the motor to the top of the mount and then tighten. Being poor sucks!!
Old Aug 15, 2004 | 10:57 AM
ZDriver96's Avatar
1.) put some resistant heater hose inbetween them (smells like burning all the time
2.) Run the hell out of your car for a week and let the engine tilt itself over and bang a dent into the header (this worked well for me, small little dent just enough to clear)
3.) Change motor mounts and it "Might" fix it
4.) get short tube headers
5.) Sell your car
6.) Pray that some divine power remedies it overnight
R@mpage
Apr 20, 2015 10:02 AM
Apr 16, 2015 09:57 AM
4586
Mar 18, 2015 06:31 PM
karnykamaro
Feb 2, 2015 01:37 PM
vb95z28conv
Jan 27, 2015 08:32 AM
