VATS/pass key.. bypass disable???
Old Jan 16, 2004 | 12:04 AM
Brians_TA's Avatar
does anyone have a link or guide for this.. my sucurity light has been comeing on when I am driving, and I am putting out the passkey II code from the computer and today the car would not start and the security light was on.. had to wait about 5 minutes and the light went off and car started.. I really want to get rid of this PITA..
Old Jan 16, 2004 | 02:13 AM
Pasky's Avatar
I don't know if this applies to the fourth gens but on the third gens, take your key with chip and have a OHM meter test the resitance on the chip. Buy a resistor with the closest ohm setting. If you take off the part of the dash under the wheel, there will be 2 wires and at the bottom of the steering column they will go to a black rectangle box thats about half an inch, think the wires were white on mine, just cut them somewhere and solder the resistor to the wires.
................Resistor
Wire 1 ----(====)---- wire 2
Double check on the fourth gens, im pretty sure they changed it.
Old Jan 16, 2004 | 08:49 AM
Brians_TA's Avatar
Ok thanks I will try see if I can find any more info in it..
Old Jan 16, 2004 | 09:04 AM
Mtrhds94Z's Avatar
Do a search
I recall this covered in some depth rather recently..
Also you don't have to cut the wires[ in caswe you want to restore it later] you can just plug the resistor['s] in the harness..
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
Aug 7, 2015 08:52 AM
