keeping close to stock compression ratio
Old Jan 15, 2004 | 07:05 PM
z28s's Avatar
im trying to figure out which type of piston i would need to keep a comp. ratio of 10.5-11:1, im doing a .030 over rebuild and im keeping stock heads. Will flat tops do it for me or do i need a dished piston. Thanks for the help
Tony
Old Jan 15, 2004 | 09:06 PM
marshall93z's Avatar
im pretty sure flat tops will do it for you, or whatever those things are that come in a stock engine.
Old Jan 15, 2004 | 09:25 PM
gb95zconv's Avatar
That depends on how much you deck the block and shave the heads and what head gasket you use. Lots of calculators out there to run the numbers on.
Old Jan 15, 2004 | 10:05 PM
he didnt mention anything about that, but you are right!
Old Jan 15, 2004 | 11:02 PM
kmook's Avatar
Advanced Tech Moderator
You need to figure out what the specs of the motor are- Gasket thickness, chamber size, deck height, etc and then you can play with the piston to see what you need to get your target c/r.
Here is one of many calcs-
https://www.camaroz28.com/calcs/cr.html
You need to figure out what your making and the variables and then you can find the answer to your question.
This should be discussed in gen tech forum though, transfering.
Thanks.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Killer94z
Jan 13, 2015 12:06 PM
