LT1 passkey system
Old Jan 18, 2004 | 12:07 AM
dshort50's Avatar
Question LT1 passkey system
Hey everyone,
I have a 93 LT1 from a corvette I am dropping into a 69 camaro, I'm using the corvette ECM to operate the fuel injectors, my problem is that the pass key system seems to be causing the injectors not to fire, is there any way to simulate the pass key system information and make this work or am I out of luck. Any ideas are greatly appreciated
Old Jan 18, 2004 | 12:09 AM
Brent94Z's Avatar
Super Moderator
You can program the chip in the ECM I do believe. Or, you can spend an hour or two figuring out which one of the 15 different resistance values it takes to over-ride the VATS
See near the end of this page...
http://www.bfranker.badz28.com/fbody/alarm96up4.htm
Old Jan 18, 2004 | 12:10 AM
dshort50's Avatar
is the odb1 chip reprogrammable or would it require a new one?
Old Jan 18, 2004 | 12:16 AM
Brent94Z's Avatar
Super Moderator
Hmm... not positive about the 93 Corvette but the 93 F-Body LT1 used an ECM with a chip. You could burn a new chip and replace it. The 94+ does not have a removable chip and you instead plug a laptop with a special program into the ALDL port and reprogram it that way... a bit easier than the 93
Old Jan 18, 2004 | 12:18 AM
dshort50's Avatar
I'll take your advise and give it a shot after all you're the expert.
Thanks for the diagram too
Old Jan 18, 2004 | 12:28 AM
dshort50's Avatar
ok heres another question is there a company that could make me a new chip or reprogram my ecm?
Old Jan 18, 2004 | 01:11 AM
97WS6SCharged's Avatar
Check with your local dealer, they should be able to supply you with a VATS disabled chip. If not, there are plenty of aftermarket chip dealers who should be able to disable the VATS with their chips. Hypertech and Superchips are probably the most prominent.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Fedesna
Nov 23, 2014 11:06 AM
