This noise is driving me crazy!!!
Old Jan 15, 2004 | 02:21 PM
Getsome17's Avatar
I was wondering if anyone has rigged up somthing to temporarly fix the elbow on the intake from leaking on the bottem side of the throttle body. The underside of the elbow is ripped a little. It will be about a week till I can get a new one. I can't see it hurting any thing, and I might get a ses light but you can hear it inside the car and it is driving me nuts.
Old Jan 15, 2004 | 02:25 PM
FacelessZ's Avatar
Duct tape
Old Jan 15, 2004 | 02:31 PM
WheelmanZ28's Avatar
How badly is it ripped?
If it is just a hairline-thick crack, get some thick CA glue and it will form a tight seal. If it is a little bigger than that, u could always put on a few layers of epoxy in order to seal off the air leak.
Sooner or later though, ur gonna have to bite the bullet and just buy a new elbow.
Old Jan 15, 2004 | 02:55 PM
Getsome17's Avatar
none of the rubber is missing but It is comming apart right where it gets clamped to the throttle body on the bottem side. Do you think silcone would work or would it get too hot and melt??
Old Jan 15, 2004 | 03:43 PM
Brundle's Avatar
i dont think the silicone will have as high of a tolerance to the heat as the epoxy IMO
Old Jan 15, 2004 | 05:01 PM
actually ur wrong man.
Silicone is extremely high resistant to high temperature. Epoxy is strong and solid, whereas silicone is more flexible and malleable. Both are pretty heat resistant and would work well, but silicone may just be a better option in this case.
Old Jan 15, 2004 | 05:03 PM
Fux0redImages's Avatar
i'd get that fixed. you're sucking in unmetered air that way, and if it gets real bad, it can cause you to go dangerously lean. fix it.
Old Jan 15, 2004 | 06:27 PM
Getsome17's Avatar
ya that is why I am gonna silcone it tonight, I have to wait till payday till I can buy another one, I still gotta pay off christmas so I am low on the funds.
So just basic silcone will work then?? How hot can the stuff get till it will melt?
Old Jan 15, 2004 | 10:35 PM
Fatdog's Avatar
Cool
Get the new one from one of the vendors here($60.00 or so)(Cramer or Dal).My02
dbrockma
Feb 16, 2015 02:56 PM
karnykamaro
Feb 2, 2015 01:37 PM
Jessie4tin
Jan 7, 2015 08:53 AM
squarehead
Nov 21, 2014 08:02 PM
