which fuse?
Old Jan 16, 2004 | 07:23 PM
slverbullet's Avatar
which fuse?
which fuse is the reverse lockout and skip shift connected to? also, anyone know why my low trac light would flash while my parking brake is set?
thanks
dave
Old Jan 16, 2004 | 11:22 PM
$hawn's Avatar
Look under the fuse box cover, prolly the one in the engine bay.
Old Jan 17, 2004 | 05:28 AM
slopokrodrigez's Avatar
The one your looking for is under the hood, it is the fan/actr fuse number 6 (10 amp). It also powers the fan relays, the oxygen sensors and evaporative emissions recirculation solenoids.
As far as the low trac light goes. I've not found anything helpful in my manual but then I have OBDI. There maybe some diagnostic going on when you pull the break that occurs with your OBDII. There may also be differences with traction control. The only suggestions I can give are, try scanning for DTC's both with the light off and with the light on.
I know this sounds stupid but check the rear tail light bulbs and the third light bulb in particular. (Again, I'm an idiot when it comes to OBDII) but weird things can happen with the 3rd light. Only takes a second to look.
If no-one jumps in here, perhaps you could post in another forum and they might help.
Jeff1904
Jun 5, 2016 05:00 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
z28cam1993
Sep 9, 2015 04:08 AM
RUNMYTA
Jul 15, 2015 07:50 PM
