Hooker vs Jet Hot Long Tube Headers
Old Jan 15, 2004 | 07:22 PM
94TA_LT1's Avatar
Which would you go with? Any problems with either brand? I herd the jet hots hit the floorboards under acceleration. thanks
Old Jan 15, 2004 | 07:24 PM
94camarof1's Avatar
I've heard nothing but good about hooker :dunno:
Old Jan 15, 2004 | 08:21 PM
1996 | Z28 SS's Avatar
They both use the exact same layout and design. But I think the Jet-Hot use a slightly thicker metal for better insulation I believe. Plus it comes with their coating. I'd go with Jet-Hot.
Old Jan 15, 2004 | 08:25 PM
Birdman7389's Avatar
Hookers will do the same thing. Replace your motor mounts with some pro-thanes from thunderracing when you do any longtubes, they are like $50 IIRC. I have to reccomend the jet-hots, i wont go into too many details but their customer service is way above and beyond what I expected from a company on the net. The product is top notch as well, i love mine
Jet-Hots all the way!
Old Jan 15, 2004 | 08:48 PM
ibanez6rg's Avatar
While their layout isn't exactly the same, Jet-Hot's have thicker flanges, O2 bungs already welded in, and they're already coated inside and out. They're also available with emissions.
Old Jan 15, 2004 | 09:12 PM
Amped96's Avatar
I just got my jet-hots yesterday. I took a few pics today. One thing I did notice is that they have a D-shaped port that matches the head. I have been seeing oval ports in all the pics I have seen on here in the install guides I have been reading. I don't know if tahts good for performance, but I would think so.
I have also heard that the jethots have better ground clearance, but can't really back that up. Someone on here may know for sure.
As far as quality...they are VERY nice. I was REALLY impressed. Ultra clean ports, welds and thick flanges.
Here are some pics that I took just a few minutes ago:
http://www.wheresthe.com/mattf/camaro/Z28/01.15.04/
Old Jan 16, 2004 | 07:09 AM
Dan Oldham's Avatar
Why would he need to replace his motor mounts? I did the Hooker LTs on mine, and had no problems whatsoever.
I can't comment on the Customer Service. I haven't had to call them.
Old Jan 16, 2004 | 07:16 AM
94TA_LT1's Avatar
Do the jet-hots leak where the front header pipe that is seperate and you put a clamp on it?
Old Jan 16, 2004 | 07:53 AM
zmracing's Avatar
I think you will be pleased with either one. I would say go with which ever one you can get the best price on. The way the GP on jet-hot LTs have been looking it will probably be them.
Old Jan 16, 2004 | 09:38 AM
mr_camaro96z28's Avatar
What did you guys pay for your jet hots?
Old Jan 16, 2004 | 09:46 AM
ibanez6rg's Avatar
I got my Jet-Hots for $513 shipped with a group purchase. I haven't had any problems with my slip-tube primary leaking. I know some people have had minor problems.
Old Jan 16, 2004 | 10:03 AM
19formula94's Avatar
I believe he's suggesting to replace the motor mounts b/c it will make them easier to get in. Depending on the miles on your car chances are the stock ones have shift or twisted due to age and torque.
Old Jan 16, 2004 | 10:29 AM
Montezuma's Avatar
The motor torques to one side and can make the fitment hard, mine were pretty busted up but I cleared it by a quarter inch
Old Jan 16, 2004 | 10:45 AM
Camaro_Guru16NY's Avatar
Thats true they use a slightly thicker metal than HOOKER and you get the Jet Hot coating. A little extra never hurts.
later,
-JOhn
Old Jan 16, 2004 | 11:47 AM
Dan Oldham's Avatar
Thanks. Maybe I'll get around to putting in new motor mounts some time. I've still got my originals in there. It'll make for something to do when it gets a little bit warmer outside.
