Coolant leak
Old Jan 17, 2004 | 06:47 PM
Zachz28's Avatar
Angry Coolant leak
OK it apears that i am leaking coolant. It seams to becomeing from the "weep hole?" on the bottom of the water pump. Does this mean it is time for a new one also how much of a pain is it to replace? Any links for a how too? Thx
Old Jan 17, 2004 | 06:52 PM
ibanez6rg's Avatar
Convert to an electric w/p.
Old Jan 17, 2004 | 06:53 PM
Zachz28's Avatar
How hard is it? what needs to be moded?
Old Jan 17, 2004 | 07:36 PM
polcat1p's Avatar
Its not to bad. I thought the hardest part was scraping the old gasket off. If your car has a lot of miles, you might want to replace the opti while your doing the w.p. I dont know whats involved in the ele. w.p, but it gives a couple hp.
When the weep hole leaks it go on the opti, so i would get it replaced asap IMO.
chad
Old Jan 17, 2004 | 09:19 PM
Zachz28's Avatar
Any body know whats involved?
Old Jan 17, 2004 | 09:56 PM
97WS6SCharged's Avatar
Definately replace the opti if the water pump is leaking. You can most likely get buy with a cap and rotor replacement. To convert to an electric water pump, you will need the electric pump (a CSI is about $135 from Summit or a local hotrod shop) and a dremel tool. Basically you will pull the old water pump out of the car, press the drive gear out of it, press in a freeze plug that comes with the kit, notch the housing a bit using the dremel and put the electric motor in. Then just put the thing back into the car and wire it up.
This may help a bit.
http://ken.lowrance.com/Projects/CSI...mp/Default.htm
blac94Z
Feb 15, 2021 09:43 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Blood type Z28
Apr 8, 2015 11:34 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
dansam
Jul 20, 2002 01:10 PM
