SLP header install
Old Jan 16, 2004 | 07:17 PM
Fux0redImages's Avatar
SLP header install
I am halfway through installing SLP "midlength" headers on my car. I got everything off; manifolds, EGR, AIR and i took all the spark plugs out. Yet, I still can not fit the god damn headers in to tighten them down for the life of me. Is there a special trick to this? Do I have to take apart more ****? Thanks for your time.
Mike
Edit: I can post pics if needed.
Old Jan 16, 2004 | 07:27 PM
JoeliusZ28's Avatar
You tried going in from the bottom correct?
Old Jan 16, 2004 | 07:35 PM
polcat1p's Avatar
Are you having a hard time getting them in the car, or bolting them in place. I had a hard time bolting them in place, and i even had the motor out of the car. LOL You might have to remove the steering saft, not a big deal though.
Chad
Old Jan 16, 2004 | 07:43 PM
polcat1p's Avatar
Chad
Old Jan 16, 2004 | 08:39 PM
Yes, I've tried going in from the bottom AND top on both sides, I can't get them into place on either side. Without the steering linkage the driver side would be easy. I guess removing that is the only choice.
Old Jan 16, 2004 | 10:45 PM
I bought my headers used and they don't have the bolts that connect the y-pipe to the headers. Can someone tell me what size that is?
Old Jan 17, 2004 | 12:46 AM
Z95m6's Avatar
on my SLP's to get the drivers side in i had to remove the steering linkage and jack up the motor on that side too.
Old Jan 17, 2004 | 12:59 AM
How do you jack up the motor, where do you put the jack at? Does anyone know the size of those bolts??
Old Jan 17, 2004 | 01:19 AM
94formulabz's Avatar
passenger side: work it in from the bottom. It's a bitch. You have to have the starter off, you know that right.
Driver side:
Remove the steering linkage. Loosen the bolt(or two) that holds the ABS/brake lines in place. This. Mine dropped in from the top quite easily then.
Note: I did have my air pump removed at that time, although the mounting bracket was still on the block then. That *might* make a difference if that will work for you or not.
Good luck
-Brent
Old Jan 17, 2004 | 10:38 AM
Thanks for the help. Now anyone know the bolt size for the y-pipe to header flange?
Old Jan 17, 2004 | 11:05 AM
polcat1p's Avatar
I bought some 3/8 by 3'' S.S bolts at home depot. They were alittle long but it dosent matter.
Chad
Old Jan 17, 2004 | 11:53 AM
thanks. anyone else think this website is the greatest? I can get any answer I need within 24 hours. If it wasn't raining the headers would be put on today.
Jlo
Feb 23, 2015 12:20 PM
jim88iroc305
Aug 13, 2002 09:24 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
