Easiet way to hook up temp gauge
Old Jan 18, 2004 | 03:58 PM
1msfyter's Avatar
My stock water temp gauge DOESNT work. I ordered an auto meter temp gauge. Wher do I attach the lead wire?
Can i tap into the stock sensor? or use the one that comes with it?
Old Jan 18, 2004 | 04:02 PM
FastZinTennessee's Avatar
On the drivers side cylinder head you can see the factory coolant temp sensor towards the front of the head. It goes to the gauge on the cluster. If I was you I'd remove that sensor completely, and I've heard the autometer sender will thread right in. Be sure and put some teflon tape on the threads. This will be ok since the sensor that reads for the PCM will be untouched, it's on the waterpump housing.
Old Jan 18, 2004 | 04:33 PM
1msfyter's Avatar
Got a pic where the sender is on the block?
Old Jan 18, 2004 | 04:38 PM
On the head, not on the block.
Old Jan 18, 2004 | 04:41 PM
Not on the block, on the head. If you have manifolds it will be harder to see, but it's on the front 1/3 of the cylinder head. Has one wire going to it. You can't miss it. Do this, stand on the drivers side of the car facing the side of the motor. You see the two front bolts that hold your valve covers on? Look midway between the two and straight down, the sensor is right there in the head.
Old Jan 18, 2004 | 04:59 PM
1msfyter's Avatar
Perfect ..thanks a lot
dylan1303
May 22, 2015 12:24 PM
Biggiebound
Apr 23, 2015 08:50 AM
Biggiebound
Apr 21, 2015 11:28 PM
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
