replacing the window regulator / motor
Old Jan 15, 2004 | 08:33 PM
anasazi's Avatar
i've replaced the motor about 10 times now... and its time to replace it again
the problem is that something inside there is bent, and the big gear (regulator?) is far enough over so that it hits the motor itself, causing the motor to burn out much quicker than normal.
how does one replace the gears inside there? what is included with the "regulator" setup?
Old Jan 15, 2004 | 08:41 PM
InjectedSS's Avatar
Re: replacing the window regulator / motor
Dude my passenger side does the same trick Have you tried greasing up all the gears and all the moving parts inside the window yet? That seemed to help me a lot this time and it hasnt been acting up... YET
Old Jan 15, 2004 | 08:54 PM
anasazi's Avatar
Re: Re: replacing the window regulator / motor
yes
something is bent i'm almost 100% sure
warmeck
Feb 2, 2015 12:44 AM
capebuf
Jan 13, 2015 07:22 PM
Jazsun
Dec 29, 2014 12:14 PM
