I need taller valve covers???
Old Jan 18, 2004 | 12:39 PM
lookingformore's Avatar
Question I need taller valve covers???
In the process of repairs and one repair i need to make is to change the valve covers....They were a main problem in the installation of new 1.6 rr's and new valave springs...The height difference cause them to knock on valve cover (shop installed) and then inevitably the rocker and pushrod on #8 gave..shotting the push rod off and down.....what a mess....but it was alll because it was htting the valve cover..is this the reason.OR MAYBE IMPROPER INSTALLATION OF RR'S......DO THEY MAKE TALLER VALVE COVERS....
Old Jan 18, 2004 | 01:21 PM
You can get taller covers, but some require some attention because they do not clear the alternator. LT4 valve covers will fit without a problem, but will cost you ~$200 with all necessary pieces.
Old Jan 18, 2004 | 02:52 PM
ponyackn's Avatar
Just cut the inner supports of the valve covers, should only take a few minutes. I did that to mine in order for my 1.6's to clear.
Old Jan 18, 2004 | 02:55 PM
If he is really having problems with them hitting the top of the cover, cutting the supports is not going to help.
Old Jan 18, 2004 | 05:52 PM
12SCNDZ's Avatar
GMPP aluminum covers. There's pictures on my web site.
BTW, are they self aligning or NSA rockers? If they're NSA, are you sure you've got the right guide plates. Standard SBC plates won't work on LT1's.
Frank
Old Jan 18, 2004 | 05:53 PM
Loadre's Avatar
Frank, check your PMs.
Old Jan 18, 2004 | 06:33 PM
93Z286Speed's Avatar
Im having my heads an stuff ported along with getting new springs and RRs for my cam, am i going to need diff valve covers?
Old Jan 19, 2004 | 07:27 PM
Thanks for the advice
The are Comp Cam's self aligning......and actually i was thinking about going to a whole conversion kit for the top of the motor....LT4 set up....heads intake and hot cam set up....Do you know if the valve covers come with coversion kits like this....
Oh by the way to some...i did cut the baffles in the valve covers..and it did not help..its the hieght of valve covers.....and i have heard that some people are ok and some people have problems with height.......
Old Jan 19, 2004 | 08:03 PM
jim88iroc305's Avatar
http://www.salleechevrolet.com/Profo...ve_covers.html
141-130
GM 12497978 SBC Die Cast Polished Valve Cover (They’re Here NOW! Price is in the database.)
are the ones I used. had to grind the rear of alternator for fitment but it worked fine.
so far 5,000 miles of daily driving without incident.
good luck
Old Jan 20, 2004 | 08:31 AM
141-130
good luck
you mean the ones that say "not for 93-97 LT1" ? hehe
Old Jan 20, 2004 | 08:36 AM
got_hp?'s Avatar
http://cgi.ebay.com/ws/eBayISAPI.dll...&category=1467
Old Jan 20, 2004 | 09:43 AM
mongse_1's Avatar
I just got some polished centerbolt covers through Summit. No problems installing whatsoever.
Pics can be found on my link below under "new motor"
Old Jan 20, 2004 | 04:11 PM
Wow i really like the welded alum valve covers, how much were they?
Old Jan 20, 2004 | 08:20 PM
got_hp?'s Avatar
those wont fit with the stock alternator location will they?
Old Jan 20, 2004 | 08:52 PM
Cool
Dose be da ones I mean!
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
