Fuel Filter Replacement
Old Jan 16, 2004 | 01:45 PM
Fastbird93's Avatar
Is there a special tool needed for the one quick disconnect fitting on the fuel filter or is it just a squeeze type plastic one???
Old Jan 16, 2004 | 01:57 PM
mongse_1's Avatar
It's just a squeeze clip if I remember right. It's not easy to get off though...much easier to put on.
Old Jan 16, 2004 | 04:38 PM
Fastbird93's Avatar
Right on, thanks.
Old Jan 16, 2004 | 05:16 PM
got_hp?'s Avatar
hehe, have a rag handy.........i got lotsa gas on my hands prying that sucker off...........still the whole swap takes about 15 mins.
Old Jan 16, 2004 | 05:47 PM
1995greenTA's Avatar
yeah as stated above, have some rags handy and dont lay right under which should be obvious but its a pretty easy instalation!
Old Jan 16, 2004 | 06:44 PM
PatriotTA's Avatar
Yeah the first time is a PITA, and you get gas everywhere, but after that its pretty simple.
Old Jan 16, 2004 | 06:52 PM
HBHRacing's Avatar
make sure you releve the pressure by taking the gas cap off and depressing the schrader valve on the fuel rail..
what I do is take a pair of neddle nose pliers to depress the tabs and then a screwdriver to pry it off. it;s really not bad at all... just try getting the ford internal disconnect filters off I did one today on a ranger... what a PITA
PCLZ28
Dec 24, 2015 05:19 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Deadbolt24
Jan 19, 2015 01:29 PM
30thZ4C
Dec 26, 2014 05:09 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
