stock studs with GM 1.6 SA rockers
Old Jan 15, 2004 | 04:58 PM
FacelessZ's Avatar
I'll be fine using my stock studs when I install my GM 1.6 SA rockers tomorrow, right? These rockers should also be alright with my stock springs for now...right?
Old Jan 15, 2004 | 06:17 PM
Mystic95Z's Avatar
The stock studs will be fine for the GMPP 1.6RR's. The springs are another thing though, if its a stock cam you should be ok. If you are using an aftermarket cam with more lift than stock, I would look into getting some better springs.
-Tony
Old Jan 15, 2004 | 06:41 PM
FacelessZ's Avatar
yeah I'm going to be keeping the stock cam and changing out the springs again when I do my cam swap...
Thanks!
Old Jan 15, 2004 | 07:43 PM
30thannZ28's Avatar
I just got new heads, and I had Lloyd Elliott use 7/16" stud instead of 3/8" ones because it wasn't much extra $$$ to do, and I got a fairly "aggressive" cam (see sig). I only did it for peace of mind, you should be fine tho.
Old Jan 15, 2004 | 08:08 PM
FacelessZ's Avatar
Yes after I have Lloyd port a set of heads I'll most likely sell these rockers and go with NSA 1/6 rockers with 7/16 stud. That and a nice set of Crane 99893 springs and I should be set...just a bit low on funds after my TT2 purchase.
Lloyd is a great guy! He lives about an hour from me in Red Oak, TX...
Old Jan 15, 2004 | 08:53 PM
97WS6SCharged's Avatar
My friend used the stock springs for a few months with 1.6 rockers, he would get into valve float around 5500 rpm. Just be careful.
Old Jan 15, 2004 | 08:56 PM
FacelessZ's Avatar
Valve float above 5500 rpms? Even with the stock cam?
Old Jan 15, 2004 | 09:05 PM
FastZinTennessee's Avatar
No problems with the factory studs. I'm using them with no problem. You'll run into problems with the stock springs though.
alliance12364
Mar 6, 2015 04:39 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
