Best way to check timing is correct before installing cover???
Old Jan 16, 2004 | 05:57 PM
Brandon 95 Z28's Avatar
Question Best way to check timing is correct before installing cover???
I just installed my cam and double roller timing chain, and want to be 100% sure the timing is correct before I bolt the cover on. When I disasemmbled the cover, it was jsut about at #6 tdc, with the cam sprocket just past the crank by a small smount. I installed it the same way, and then inserted a bolt into the crank and turned it, and it appears to be fine at #1 and #6 tdc, because the dots lined up fine. After I removed the bolt, the crank gear shifted a little to the left, and the cam gear to the right, so the marks are a little off, but the cam is still at 3'o clock, and I think it is set up right, so should I be ok??
Thanks,
Brandon
Old Jan 16, 2004 | 07:58 PM
Don 97 SS's Avatar
Put the #1 cylinder at TDC, then the dot on the crank sprocket at 12:00, the cam sprocket should be at 6:00. Rotate the crank a full revolution to verify the timing marks remain aligned.
Old Jan 16, 2004 | 09:14 PM
Hot Rod Hawk's Avatar
you could verify this with a degree wheel and the cam card that came with your camshaft.
*Emilia*
May 13, 2015 09:05 AM
Queens94z28
Dec 20, 2014 09:11 PM
Dec 4, 2014 11:56 AM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
