ticking sound
Put a screw driver to the valve covers and see if you can pinpoint the ticking ...or the OL' my Daddy's a Doctor routine and put a stethoscope up to the valve covers and see if you can hear it out...If you find nothing get a flash light and look for Carbon build up around the intake manifold..and heads.
as you rev the engine slightly to say 3k rpm does the noise disapear? is the tapping present only during low oil presure? that would mean its mostly likely a lifter.
if it dosnt have those traites exactly and it sounds more or less like a high pitched tick noise then look for a loose manifold bolt or exhaust leak.....check around visualy.
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
