Car randomly dies...seems ignition switch related
Old Jan 18, 2004 | 04:16 PM
Robert95z's Avatar
I could just be driving down the street and the car will die... no accessories, no radio, no ignition... I do get head lights, etc... but When i turn the key back i will not get any accessories/radio...
Its done this before so I did replace the ignition switch (PITA!!!) and it worked... now its doing again, but its weird... If i reach all the way under the steering column and wiggle around the ignition switch connections it will start working again... but will die again most likely later that day, but just gotta wiggle the connections and it will start working again
Old Jan 18, 2004 | 04:33 PM
I will almost bet you that this connector on your ignition switch is not making good contact. If it is not too damaged by heat, you can carefully rebend the terminal to make it tighten up. The other choice is to replace it with a new pigtail. Info in my ignition switch replacement guide.
Old Jan 18, 2004 | 05:13 PM
Robert95z's Avatar
well crap... I even used your guide when i did my install and didnt even bother looking at the connectors... guess i gotta take it all apart and take a look... and putting that iginition switch in is a pita! lol
Thanks shoebox
Old Jan 18, 2004 | 05:24 PM
Thanks shoebox
Oops, that is why I specifically mention it in my write-up.
A little hard to get to, but you should be able to get the connector off without having to take things apart. It's just hard to work under there while standing on your head.
fpete1992
Dec 11, 2014 03:51 PM
nophix
Nov 30, 2014 10:26 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
