rear brake rotor install?
Old Jan 17, 2004 | 11:34 PM
NewbieWar's Avatar
ok can anyone walk me through this procedure? im gonna do it in the morning and if u guys could help me out it be great
Old Jan 17, 2004 | 11:47 PM
The rotor should practically fall off, once the caliper is removed (if there are no star washers holding it on). The rotor is sandwiched by the lug nuts, wheel and axle flange. There is nothing else that holds it on.
Old Jan 18, 2004 | 12:02 AM
S.J.S.'s Avatar
Simple as hell buddy. Like Rob said, just pull the tire, unbolt the caliper, pull it off the rotor and the rotor will just come off. Takes about 5 minutes for the whole procedure.
Old Jan 18, 2004 | 04:46 PM
NewbieWar's Avatar
ok i got a question... i was looking thro shoeboxes pictures and his rear break calipers and the way i put mine, the spring thing on the bottom of the pads i put them both on the outside of the caliper and i see thats not the way it is on his, should i redo it?
Old Jan 18, 2004 | 05:35 PM
The wire springs on the caliper definitely go on the inside.
Chet1185
Feb 4, 2015 09:51 PM
Jazsun
Dec 29, 2014 12:14 PM
bossco
Nov 29, 2014 10:18 AM
Wilson
Jul 21, 2002 05:08 PM
