Fuel pump, check ball questions.
Old Jan 17, 2004 | 10:03 AM
Phatcaprice's Avatar
I'm about to change out the fuel pump in my car and was wondering, is the check ball (that prevents fuel drain back) part of the pump itself, or is it a separate part? I question this because before the pump failure (10-20 psi throughout all RPMs), I would have hard starts, meaning no pressure in the lines after engine shutdown (after many hours), unless I turned the key back and forth until the pump primed the lines. Mind as well change it while I'm in there right? FYI, there are no external leaks, and I've yet to check for injector leakage, so that's still a possibilty. Thanks in advance.
Old Jan 17, 2004 | 10:30 AM
engineermike's Avatar
The check valve is built into the pump.
Mike
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
RiverMutant96
Jan 30, 2015 09:21 AM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
ANDYZ28
Dec 29, 2014 09:13 PM
