Vac from opti/94 intake
Old Jan 15, 2004 | 06:38 PM
ibanez6rg's Avatar
Since I'll be converting to a 95+ opti, where shall I hook up on the intake. Will it work in place of the EGR solenoid fitting?
Old Jan 15, 2004 | 06:42 PM
If you removed the EGR, then you can use the fitting that fed vacuum to it. If not, then you can put a tee in the line to feed the opti.
Old Jan 15, 2004 | 06:47 PM
ibanez6rg's Avatar
Yea, EGR is removed, just making sure I could use that.
Rob, do you know the p/n for the vac harness.
I found it as P/N 12554395, but that doesn't work.
Old Jan 15, 2004 | 09:28 PM
Not sure where you got that number, but it is GM PART # 12555323.
Old Jan 15, 2004 | 09:42 PM
ibanez6rg's Avatar
That P/N was on GMPartsDirect, guess they messed up.
Old Jan 16, 2004 | 12:18 PM
QUASARBLUEZ28's Avatar
Shoebox has the correct part#. It was $11.15 from Jason Crommer.
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
MadMav
Jun 15, 2015 09:51 PM
jwade88
Jun 14, 2015 09:38 PM
Countryboychevy
Jun 13, 2015 02:49 PM
maybe2fast
Mar 26, 2015 08:34 AM
