LT1 headers question
Old Jan 16, 2004 | 10:22 PM
JDBlaze85's Avatar
Will LT1 headers work on pre 87 sbc heads?
are the exhaust ports the same and is the bolt pattern the same?
Old Jan 16, 2004 | 11:00 PM
Spinner's Avatar
I dont think so because LT1s have a D shaped exhaust port.
Old Jan 16, 2004 | 11:02 PM
Heatmaker's Avatar
Advanced Member
depends on wether the block is a D-port or not... Forgot what they had in 87...was that TPI?
Old Jan 16, 2004 | 11:33 PM
JDBlaze85's Avatar
the ports are D shaped with the flat angle of the "D" on the bottom. Is the bolt pattern the same?
Old Jan 17, 2004 | 03:35 AM
billsbird's Avatar
...yeah but Hooker part # 2231-1 states; '93-'97, Chev/Pont, 265-400, ceramic coated, Super Competition headers. Why does it say 265-400 if they only fit the LT1's? They must fit, right? Bill...
Old Jan 17, 2004 | 03:42 AM
97WS6SCharged's Avatar
Are you using LT1 headers on a 4th gen with a gen 1 SBC in it? What's the setup?
Old Jan 17, 2004 | 03:53 PM
JDBlaze85's Avatar
yes im putting in a 360 sbc gen 1 into my 4th gen. just sat the engine in today no problem. Now i need some headers and was hoping if someone could tell me if they would work just the same on a gen 1 engine. I would like to get the 4th gen long tube headers because they should obviously fit no prob.
Old Jan 17, 2004 | 05:40 PM
97SS0594's Avatar
id make some cusom heders if your good w/ a welder or have them made, a freind of mine put a 355 in a 85 jaguar xj5 and he had to have some custome headers made fore it because of space.
Old Jan 17, 2004 | 05:56 PM
93Z4ME's Avatar
Easiest way to check would be to get a set of each type of gasket and see how they compare against each head. If the bolt pattern (spacing) is the same and the header tubes/flanges are larger than the port on the head then the LT1 headers may work on the older style heads.
Old Jan 17, 2004 | 08:30 PM
I'd say as long as the flanges are round and not a D port shape, they should work.
Old Jan 18, 2004 | 12:47 AM
JDBlaze85's Avatar
can any of yall remember if the headers you got for you LT1s were round, square, or "D" shaped? I got the camel hump heads straight plug and they got the oval exhaust ports. not a perfect circle but like a rounded out square shape.
cmdeshon
Dec 27, 2014 10:06 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
Jul 4, 2005 05:00 PM
