Oil level sensor.....( Canton Oil Pans )
Hey guys got a question about this sensor on the Canton Pan. Its the stock sensor. The directions say that upon installing the pan to put 6 quarts in and check the level...that will be the new full level for the pan. When I did, it barely hit the A on the ADD line. Whatever. After about 2k the low oil level light went on. I added 1/2 quart and it went off.
So heres my question does it not matter what the sensor says?? I figure low oil level is still a low oil level? Should I add more even the directions say its fine?
Thanks .....
Thanks .....
Originally posted by dreamer1q
Cut it off and weld it up. Thats what I had to do to clear my headers. BTW Canton sucks
Milodon has a pan?
lets think about this for a sec...the location or depth of the dipstick never changed, just the size and shape of the oil pan.....so shouldnt you still fill you pan till the dipstick says its full....i mean it only makes sense
Cant blame a brother, I really hate them
I hear talk about a Milodon pan, but I see no part #'s or info?
Also, RE: Dipstick length. I believe the oil level only has to be high enough to cover the pickup completely submerged during all actions of the car, no need to OVER fill it, correct?
JasonD
08-23-2010 03:14 PM
JasonD
07-27-2002 08:57 PM
