LT1 Throttle Body question
Old Jan 17, 2004 | 02:13 AM
o-zone's Avatar
Hey there everyone, I just wanted to know if it is possible
to remove my stock throttle body ( 97' LT1 SS ), and have
a machinist make it larger, ie: 52mm instead of the stock
48mm. So I don't have to spend 4 or 500 dollars on an aftermarket one. And how complicated is it to do?...
Cheers...
Old Jan 17, 2004 | 02:24 AM
97WS6SCharged's Avatar
Yeah, it can be done. It's about as complicated as having the throttle bores opened up and making new throttle plates. There's a guy on the board who does this. I don't remember who, maybe someone else can help a failing memory.
Old Jan 17, 2004 | 02:50 AM
o-zone's Avatar
Thottle body question
Hey thanks Chris,
So I guess my friend can't just bring
it to work & zip off 4mm on a lathe or milling machine for
me & call it a day, sounds like there is more to it.
I priced out a Holley 52mm here in Canada & they
want over $500 can. for it.
Steven
Old Jan 17, 2004 | 02:59 AM
Well, he could, but then he has to machine bigger throttle plates to fill up the bigger holes.
Old Jan 17, 2004 | 03:09 AM
Zerosheaven's Avatar
corect me if im wrong, but isnt that usless without boring out the intake manifold??
Old Jan 17, 2004 | 03:12 AM
o-zone's Avatar
Well I guess I will have to take off the throttle body this
weekend & see what I am in for, I have a full machine
shop @ work to use if I go this route. I'm trying to get all
mods done before spring.
Steven
Old Jan 17, 2004 | 03:19 AM
o-zone's Avatar
Hey zerosheaven, from what I have been told, I should'nt
have to because the intake is already@ 52mm. If I wanted
to go larger then yes.
Cheers...
Old Jan 17, 2004 | 03:44 AM
Yeah, the throttle bores on the intake manifold are 52mm. You only have to open them up if you want to go to a 58 mm or a monoblade TB.
Old Jan 17, 2004 | 04:06 AM
ah, thaks for clearing that up
Old Jan 17, 2004 | 10:45 AM
blazebdb's Avatar
If you decide to buy one look at Summitracings 52mm BBK throttle body. They are the cheapest I found. I got one recently and am quite pleased.
Old Jan 17, 2004 | 11:09 AM
FastWhiteTA's Avatar
Thunder racing sells ported stock ones for $225 + core charge. That's going to be the best deal. On a mostly stock car, a 52mm TB doesn't do very much anyway so I'd go with that one. I did, and it works fine.
Old Jan 17, 2004 | 11:18 AM
EbeZ28's Avatar
The board member's website is www.halbertperformance.com. They ask $150 + core for an overbored 52mm. They are shipping me the new unit, and letting me ship back the core when the install is done (my car is a daily driver). Shannon and/or Heather have been a real pleasure to work with
Old Jan 17, 2004 | 01:55 PM
dren70's Avatar
From: brunswick ohio, small burb south of cleveland
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEBWN%3AIT
got this off ebay for 219.00 modifying my TB. this was a 53.5 flows 825 cfm (alledgedly). he also does the 52 for like 159. mine is in shipping on the way back.
Old Jan 17, 2004 | 08:38 PM
o-zone's Avatar
Thanx everyone for the info. I am going to check out the
web sites mentioned in your reply's & see if I can find what
I am looking for. I also wanted a 52mm TB so that I wouldn't
have to bore out my intake manifold.
Cheers,
Steven...
Old Jan 17, 2004 | 11:11 PM
fireman's Avatar
I paid a local machine shop to bore mine out to 52mm($100) and to install the 52mm blades I bought from AZ speed & marine($25).
Total cost-$125
