low coolant level light in 94 Z28, need advice
Old Jan 18, 2004 | 12:30 AM
nuc79's Avatar
Ok, first off, we don't drive the car much. In fact, 2500 miles in the 18 months we've owned it.
But recently the red "low coolant level" indicator on the dash has come on and won't go off.
I followed the refill instructions per the owners' manual to a tee, bleed valves and all. The system appears comepletely full, but the light won't go off.
Also noticed the temp never goes above 160, or approx the lower 1/4 to 1/3 of the temp gauge. Althougt the electric fan does turn on and off as expected
And the heater doesn't seem to get as hot as it should, even though we rarely use it. Most of the time the car is out in nice weather with the top down.
My first instinct said faulty thermostat, but that doesn't seem to explain the warning light.
Old Jan 18, 2004 | 12:32 AM
bigj96z's Avatar
mine's doin the exact same thing...is it prolly just a sensor that has gone bad on it?
Old Jan 18, 2004 | 12:35 AM
Sneakin Deacon's Avatar
the sensor is notorious for going...i swore i had a blown headgasket for almost a week even after checking compression on all the cylinders, and about 5 minutes before i was going to pull my heads i had to try one last thing.
Fill your coolant resevoir, fill your radiator and bleed it properly and such. drive around a while, and just check the resevior from time to time...if there is no coolant missing, your fine.
Old Jan 18, 2004 | 12:36 AM
RedHottG2's Avatar
it's just the sensor...you can either replace it or just unplug it...it's located under the radiator on the pass. side
Old Jan 18, 2004 | 12:40 AM
bigj96z's Avatar
aight...i will prolly just unplug it cuz most of those sensors are expensive....does anybody know how much that one runs?...just curious
Old Jan 18, 2004 | 12:46 AM
nuc79's Avatar
Thanks for the quick replies. I'm new to the forum, but that's the fastest I've ever had any car question answered on an online forum.
I'll replace that sensor tomorrow.
***EDIT: for $44, I'll just bypass it or try to clean it up http://www.partsamerica.com/PartDeta...e=1178&PTSet=A ***
Hopefully the heater problem is just a stuck open thermostat or something. Not much of a concern here in FL anyway.
Next issue to tackle is the 4L60E rebuild. Has no grab from a standing start until 1100 rpms, then grabs and takes off with a clunking/rumbling sound. And the 1->2 shift is a major slip-fest...
oh, the woes that are F-body... reminds me of my first car(79 Firebird Formula)
Old Jan 18, 2004 | 01:17 AM
RedHottG2's Avatar
I think the sensors are like $8 or maybe $12. cant remember what it was when I replaced mine but there not expensive at all.
Old Jan 18, 2004 | 01:56 AM
Spllouder's Avatar
try to clean the sensor when u do ur flush b/c most of the time they are gunked up then replace if it still is failing
AlaskaZ28
Jan 1, 2015 12:30 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
