Fuel Pump Switch
Old Jan 17, 2004 | 01:18 PM
Don't Look Back's Avatar
Fuel Pump Switch
Hey guys, I was thinking of installing a manual fuel pump switch (for security) hidden somewhere in the immediate area around the driver's seat. Wondering if anyone has done this, if its possible, and possible ideas of where to hide it.
Thanks, Keith
Old Jan 17, 2004 | 02:11 PM
SDAKOVIC's Avatar
I use a double throw relay I bought at Radio Shack. How this works is I have to push and hold my hidden switch down until the car starts,then I let go and the relays stay energized until I turn the car off. The reason I went with this set up is that it's fool proof and I won't ever forget to turn off the switch,it does it all by its self when I turn the car off. The wires for the fuel pump are located under the passanger rear seat,real easy to get to. It has been awhile since I put it in and don't remember the color of the wires. Just use your test light and you will figure it out. Good luck.
grabbem88
Apr 16, 2015 06:57 PM
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
