Where to Clearance Timing Cover for Double Roller Chain??
Old Jan 16, 2004 | 05:52 PM
Brandon 95 Z28's Avatar
I have installed my Cmotorsports double roller chain, and was wondering where I should clearance the timing cover for it. Is the main problem area the chain around the cam sprocket? Do I also have to cleanace down by the crank sprocket? I tried a test fit, and it was kind of hard to tell what needed to be clearanced.
Thanks,
Brandon
Old Jan 16, 2004 | 08:52 PM
jay g's Avatar
test fit it but leave it a bit loose and spin the engine over by hand then remove the cover and grind where the rub marks are,
i used a cloyes double roller with no clearance issues
jay
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
Queens94z28
Dec 20, 2014 09:11 PM
97 RedSS
Jun 10, 2003 07:58 PM
