Front Seal ?
Hey All, I seem to have a front seal leaking engine oil. Does the seal come out the front after you remove the Harmonic balancer (Like the old 350's), or do you have to take the front cover off to remove it? Thanks, Later>>>>>>>
Remove the damper[3 bolts] then the hub[on the crank, one bolt in center]using the appropriate pullers, then the seal in the usual manner..
A search may help with hub removal techniques etc..
Magenta_Hearts
Mar 29, 2017 08:54 PM
Brake_L8
Jan 20, 2015 09:44 AM
