View Full Version : LT1 Based Engine Tech
- Whats up next for mods?
- What temp are you guys running?
- Nos 5177 Kit on a stock 1995 A4 T/A???
- Is this my TC?
- How can I find out which gears I have?
- !air
- Help me bring my Chrome TA wheels back from the dead...
- motor mount install?
- Coolant temp for LT1 Engine swap
- High volume oil pump question(Do you remove the top of the pump to change the spring)
- best place to get AFR 220's
- careless mistake, need firing order of opti
- Need some help!!!! Timing Chain Cover Questions
- electric water pump question
- is the pro 5.0 deal still going on?
- Magnaflow catback installed... Sound clips inside.
- Trying to get rid of the ABSinop light and the brake light from BCM what wires
- Temp gage pegged, then drops instantly
- lt1 service engine code
- Took off brake booster hose and smelled gas
- Can I use a 200 amp alternator
- 1LE Elbow
- where is the best place to get O2 sensor extentions
- WTF? exteremly dissappointed...
- Interior color
- Why will my clutch fork not stay put!
- tubular K-members ???
- Bad Optispark?
- I measured the TPS voltage....
- vette servo
- Sputtering, Bad Opti?
- is there a fix to low backpressure?????
- tuning in real time with RT Tuner
- What to use to cut down Pro 5.0 shifter??
- Hot day, coolent temp does weird things.
- Only when its hot
- How many connectors on a 95 Coil?
- Photos of KB SFC installation?
- Part Number
- If you had my mods, what would your next step be?
- What Plugs, NOT BOSCH??
- Forged 396 and piston slap...
- Need quick help with Air Pump
- Torque Thrusts 2s 16x8
- spring seats
- balancer help
- WS6 exhaust
- just ran my car with un-bolted exhaust right after cat!!!
- Guys with the 847 cam, come inside please
- fast burn heads for lt1
- ? on high effieciency oil filters.
- What kind of heads with hotcam??
- Help with clutch problem…
- How much are AC Delco plug wires.
- Why won't my car hold first gear?
- waterpump won't come off..
- Rear Main Seal?
- Idler Pulley?? (Shoebox)?
- Anyone have any experience with the xe224/236
- Valve Spring Question
- Comp or Isky guideplates?
- Installing KBDD SFC's
- TPIS and Hypertech Airfoil the same??
- Line-lock, burn out question...
- How much HP have you LT1 guys got away with spraying dry N2O in front of the MAF?
- New coil; which one?
- V6 black steel wheels????
- Im doin the dreaded
- spark plugs
- right stock cam spec for 94-95 lt1
- Download a Camaro parts book
- i have a bin file for 230/236/112 done by andrew mattei if anyone needs it.
- Y pipe options ? dual cat, emissions legal
- bin file for a stock Z
- what to do about maf??
- Noisy rear suspension
- Rear question(is this normal)
- SLP header y-pipe leaks????
- i'm an idiot, please forgive me
- How Do These Flow #'s Look?
- Quick question about the starter wires
- Are Copperseal Exhaust Gaskets reuseable?
- Do NOT Order Parts from Racenet/IRS!
- anyone have a set of aft 210 they are willing to part with?
- What just Happened!?
- help! Exhaust leak
- POLY tranny mounts suck!?!?
- Clutch install gone horribly downhill!
- HVAC control lighting question...
- please let me know if I've forgot anything!
- Removing/gutting cats ticks me off!
- LT1 reliability??
- Interior lights flash on bumps
- Manley Race series vs Manley Heavy duty valves
- PCMforless.com
- MPH vs. E/T
- gutting my cat.
- Called bryan
- How do I remove the dash?
- tunercat 1.98
- Last Electric WP ? i promise!
- question about 24lb svo????
- Anyway to tell what # my Z came off the line?
- Pass Cyl Head not coming "right off"
- Installed my K&N FIPK today.
- cutout, causes turbulance??
- Opti is gone, replace or upgrade to vented?
- GM 847 sound clip
- 94 Z28 Front impact bar and plastic support part numbers please!
- Sucky off the line
- Powersteering pump.
- TB question... blades close completely with car off, stays 1% open with car on????
- keep blowing my driver's side rear...
- Thinking of doing a little stroking!!
- In need of 350 rebuild kit, any suggestions?
- Pontiac guys, where did you mount your 6AL?
- Help me figure out whats wrong now please.
- couple lt4 questions
- powerprogrammer shift firmness
- wheel size using stock size 16by8
- Timing and fan temp. questions
- Where can I buy a LT4 KM online??
- just got my hooker catback!!!!!!!!!!!!!!
- SLP LoudMouth Exhaust...
- BOLTON+CAM guys...w/stock heads...post your MPH/dyno
- Clutch Info...
- Need advice on valve spring kit and lifters.
- TPS bolt size???
- Another Cat question....
- how long to expect for waterpump install?
- Pics of my new ride!
- How rare is a '96 SS with an automatic?
- Stage 8 Collector Bolts?
- Were does this ground go?
- o2 sensor connections
- Newbie...Please help!!
- 96 4L60E into a 94?
- headers are rusting`
- Dead Cylinder
- Anyone know the # to SPEC? nt
- Question about exhaust. Can it be improved?
- port and polish my heads
- Will these TRW's handle 550 RWHP?
- Got the the Z running
- 32 valve?
- i swaped rearends, now clucking noise from the back!!
- Best Street Tires
- Trans-go question
- Trans-go people inside
- *Urgent* How do I break loose the flywheel bolts?
- pcm forless??
- Car has 93k on it. H/C or just build a new motor?
- Still when its hot
- *Need Help Quick!* Trouble removing the flywheel housing..
- how do you change a/f ratio a wot. with tuner cat.
- Weird #s coming from my O2 sensor: Can you help
- BMR lowering springs
- Anyone Familiar w/ 42# SVO Injectors?
- low coolant light
- Opti conversion Question
- LT4 conversion isn't working
- Is there any way reverse the fading in cloth seats?
- New Opti Coming, Whats should I do?
- big problem with 1074 head gasket
- '94 will not start
- Anybody buy a tranny from these guys?
- What pads for Track Kit ?
- ok, 2-3 clutches were replaced and the problem still isnt solved
- Why does the hpp3 suck?
- When will us A4 guys get to have a REAL shifter
- How to install comp R lifters
- ZR-1 Specs
- 383 finally running!!!!
- lt1 bottom end weight
- SPEC problem?
- bosch o2 sensor wire question
- Radio/Power Windows Problems
- Clutch won't engage!!
- Remember my other thread? Now I KNOW my car is slow!!
- Just ordered lt4 top end conversion
- Length of pipe after muffler
- How hard is a 4L60e to T56 swap
- is there any good 12 bolt donor cars?
- Can worn shocks cause alignment probs?
- I'm impressed with the Borla Cat!
- securety light??? car wont start!!!!!!!
- lt1 block casting number?
- Stereo troubles need help please!!
- Cost on Jet Hot coating on Hooker LT's!!??
- Blown Header Gasket Removal
- Z coming along great!
- Paging shoebox
- Can I make the 4 channel ABS work on my 95? Need to!
- replacing water pump
- how to change the idle with TC
- Opti ?
- Horsepower Problem, Scanned Car, Observations....Need Expert Help!!..Long!
- Vibrating shifter, only in 6th gear?
- ac delete and computer help
- Need clutch
- Major VIbration issue!!?!?!?!????
- LT1 underdrive pulleys
- New project...How hard to put an LT1 in this.......
- MSD problem
- Problems with '94 Vette. Opti? ICM?
- lets drop off a few tenths
- My car won't start
- Header bolts
- Another high RPM miss thread!!
- Could I have 3.73s???
- White smoke at start-up
- What should I do with $1500? I thought a cam, but...
- stock radio question
- Firebird Headlight Problems!
- wheels
- Oil leak -- Front cover
- Best, cheapest place to get a 12 bolt??
- Electricians.. I need your help please
- Do air foils really work?
- Rattling In My Tranny???
- How to check EGR valve?
- Does anything in the throttle body change when the car goes from "on" to "start"
- electric water pump guys inside
- ET Streets on 10-bolt?
- Subframe Connecter install Question
- Starter... HELP!!!
- Got a Dynomouth system made today (pics)
- car would not start
- Wiring into the computer
- Any Street Twin owners have trouble with pilot bearings????
- HELP!! Car overheating and SES light on!......long sorry.
- Opti CRAP problems again
- Bad Optispark
- Need help ignition problems?
- What modifications do you have to do to valve covers for Roller Rockers
- How much Power ...
- 97 Z/28, ABS INOP shortly after header Install???
- Bose Amps?
- Price Of Timing Chain Set?
- Hal users, What settings for the Track?
- What's the most HP and Torque for a stock steel driveshaft?
- True Dual - ers INSIDE
- BMR tunnel brace first impression
- coated intakes
- i got a new block today
- BANGING Valvetrain Noise
- Smog Pump
- Looking at a 94 Z28 A4 have question?
- Cant get the tranny loose to drop it!!
