electric water pump guys inside
Old May 14, 2003 | 06:33 PM
CamaroRob97's Avatar
Does anyone know how to go about removing water pump gear shafts?
Also, what is the best way to remove the Impeller (the stock water pump)?
Thanks.
Old May 14, 2003 | 08:33 PM
12SCNDZ's Avatar
I used a shop press. The impeller shaft is pressed out from the front, and then the bearing is pressed out from the rear.
Frank
Old May 15, 2003 | 12:30 AM
Formula_one's Avatar
I had to take it to a shop like he said too, that sledge hammer just wasnt doing the job....lol
Old May 15, 2003 | 01:01 AM
FastZinTennessee's Avatar
I didn't have a big enough hammer, had a shop press mine out.
John
Old May 15, 2003 | 01:12 AM
94_Camaro_LT-1's Avatar
BIG HAMMER
Old May 15, 2003 | 03:04 AM
91RSLT1's Avatar
Do a search on the install, or check out projecttransam.com. It has a install guide that work for my CSI intall, good luck.
Old May 15, 2003 | 07:28 AM
mongse_1's Avatar
Be careful when you're pressing the shaft out too. I broke the little aluminum collar that holds the bearings to the shaft. It's amazing how far ball bearings will fly.
Old May 15, 2003 | 08:46 AM
johnpsz's Avatar
Check this page out he has good info.
http://ken.lowrance.com/Projects/CSI...mp/Default.htm
Old May 15, 2003 | 12:21 PM
Lunarson's Avatar
I got mine with a 3" claw puller, the same one I used to put my underdrive pulley on with. I hooked it onto the impeller to pull it off then I turned the claws around and hooked to the housing to push the shaft out, piece of cake.
HectorM52
Jul 30, 2017 11:46 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
