Vibrating shifter, only in 6th gear?
Old May 14, 2003 | 09:37 PM
96z's Avatar
96z
Today while crusing on the highway I went to put it into 6th at about 75 mph and the shifter started to shake alot and made noise. There is no problem with any other gear....
Anyone have any idea?
Old May 14, 2003 | 10:42 PM
slashz28's Avatar
what gears you got? 3.42's? if so, i suppose youre at or a bit under 2k rpm? have you tried 5th at speeds under 2k rpm? does it do the same? if so, my guess would be plug wires
Old May 14, 2003 | 11:36 PM
Koors96Z's Avatar
mine shakes at low rpms too, so its the wires?
Old May 14, 2003 | 11:47 PM
93formula's Avatar
broken tranny mount?
Old May 15, 2003 | 12:19 AM
fbird95's Avatar
If jsut the shifter shakes, i wouldnt worry about it too much, unless it shakes a lot. My shifter shakes in almost every gear. Most likely the good old Gm factory tranny mount is old and mushy and wants to be upgradded to a poly mount. If the whole car shakes it probably plug wires as stated above.
Old May 15, 2003 | 01:05 AM
96z's Avatar
96z
Yeah now that I think about its probably the gearing...stupid question.
BigWil
Mar 29, 2015 12:24 PM
ChrisFrez
Mar 22, 2015 07:00 PM
ChrisFrez
Feb 22, 2015 08:47 AM
ChrisFrez
Dec 21, 2014 09:47 PM
