Newbie...Please help!!
Old May 15, 2003 | 04:04 PM
ReeZone's Avatar
I have recently baught my 94 Z28 and am new to this forum so please forgive any ignorance.
I have done some searching around but thaught it would be better if I posted my particular problem.
I was getting the from what I see usuall 1 - 2k miss/stumble/hesitation but then ran very strong through the rest of the RPMs
so I changed the wires. nothing
cleaned the MAF - nothing
changed the MAP sensor - nothing
pulled the vacuum on the egr and plugged the solenoid- nothing
Then after driving the car most of the morning I get back into the car and start it and it has this terrible miss..kinda like a dead cylinder. out of no where. Tremendous loss of power. so then
Changed the spark plugs - nothing
unplugged the MAF so it would use the default table - nothing
checked fuel pressure - OK
any one have any suggestions. I would hate to buy an Opti and still have the problem
Old May 15, 2003 | 04:24 PM
94 CAMRO Z28's Avatar
Seeing that the problem is going down hill and it seems like an ignition problem since your fuel pressure was good, I would have to vote for the opti. Also, since its a '94 its likely its up to about the end of its lifespan.
Aaron
Old May 15, 2003 | 04:27 PM
teke184's Avatar
low rpm miss is 9 times out of 10 the optispark...
do a search and you'll find tons of info on how to replace it.
for the cheapest price on a new one contact jason chromer or is it cromer?
do a search and you'll find his contact info as well
Old May 15, 2003 | 04:31 PM
ReeZone's Avatar
Also I scanned it and am getting no codes
Old May 15, 2003 | 04:36 PM
chasmanz28's Avatar
change the coil and the wire first, cheaper than the opti, if that doesnt work its time for a new opti
Old May 15, 2003 | 05:20 PM
cals400ex's Avatar
who scanned it for you?
Old May 15, 2003 | 05:38 PM
ReeZone's Avatar
a buddy of mine has a shop and used a 'Snap-On' scanner...
Old May 15, 2003 | 06:15 PM
Good call, this is a good reason to upgrade to a MSD Blaster coil. Even if it doesn't fix the problem its still nice to have and only costs about $35-40.
Aaron
Old May 17, 2003 | 02:29 AM
Fatdog's Avatar
Cool
I would spray some (cat approved) carb cleaner on that little wire in intake mass air sensor,and see if that helps,then do the coil wire.If the opti was going,it would be a horrible ride.Also see if the water pump is leaking down onto the opti.Everybody likes to blame the opti for a lot of stuff,when actually it's other issues.Do the cheap stuff first.My02
Old May 17, 2003 | 02:45 PM
ReeZone's Avatar
Thank you everyone for all of your replies....
I have solved the problem......plug wire 7 was touching the header and burnt through.....it was a new wire....replaced it...everything ok...
Now back to the good ole 1-2k stumble
Old May 17, 2003 | 09:57 PM
Fatdog's Avatar
Cool
Also check to make sure the manifold pressure sensor (on top of the engine)is sealed tightly.Also check the connector to it as well.The wires seem to go south with age.My02
Old May 17, 2003 | 11:35 PM
Bud M's Avatar
Aaron
I've seen a lot of complaints here about MSD coils not lasting very long on LT1s. I'd stick with the stocker.
