gutting my cat.
Old May 15, 2003 | 10:20 PM
yorkie's Avatar
gutting my cat.
I live in a state and county that requires NO emmisions testing, is it worth it to gut it. The motor is a 383.
Old May 15, 2003 | 10:25 PM
qwick_trip's Avatar
yes it's worth it. you could either gut the cat or you cant just cut the cat out and put on off road pipe in. you can either buy it or just make one. you can getsome exhaust from your local muffler place and have each end expanded , slip it on then weld it or clamp it. cost about $10 thats will flow slitly better than a hollow cat.
Old May 15, 2003 | 10:30 PM
yorkie's Avatar
hollow cat
but the hollowed out cat would be better than what it has right now (a Cat)??? I will do a "test pipe" eventually.
Old May 15, 2003 | 10:34 PM
revtime's Avatar
forget a test pipe take the cat out and put a cutout in its place.
Old May 15, 2003 | 10:37 PM
yorkie's Avatar
like a manual one?
operated manually? like a Y correct?
Old May 15, 2003 | 10:45 PM
revtime's Avatar
Manual one is best, I would think remote operated ones would leak after awhile but I am not certain.
It would just let you uncork the exhaust whenever you wanted.
Old May 15, 2003 | 10:47 PM
yorkie's Avatar
I may do it, but for now...
I will just bust out all the catalyst and gut it.
qwick_trip's Avatar
that will work to.
Old May 15, 2003 | 10:50 PM
yorkie's Avatar
any negatives to..
gutting it? How is the best way to gut it, rebar, I did one with a piece of rebar.
Old May 15, 2003 | 10:53 PM
qwick_trip's Avatar
yes if you have yor sir pump still hooked up there will be a poping noise through the exhaust when yuo rev it up. .
Old May 15, 2003 | 10:57 PM
yorkie's Avatar
so dont gut it??
I dont want the popping sound, how much gain in power will it yeild???
Old May 15, 2003 | 11:06 PM
qwick_trip's Avatar
i would gut but i would also remove your air pump no need for it since you won't have a cat anymore.
Old May 15, 2003 | 11:07 PM
94GrayV6's Avatar
5-10 hp.
Old May 15, 2003 | 11:09 PM
yorkie's Avatar
with the air pump removed...
will it still pop?
Old May 15, 2003 | 11:11 PM
qwick_trip's Avatar
with the air pump gone it won't pop.
