If you had my mods, what would your next step be?
Old May 16, 2003 | 02:13 PM
tstewart9000's Avatar
Arrow If you had my mods, what would your next step be?
Im ready for my next modification to add more HP. I'd like to do a bolt-on.
What would you do?
Old May 16, 2003 | 02:16 PM
qwick_trip's Avatar
my next choice would be headers. you'll see a big gain with that.
Old May 16, 2003 | 02:17 PM
teke184's Avatar
inexpensive mods:
-electric cutout because flowmasters are well known for being pretty restrictive.
-pullies
-electric water pump
-airfoil
-ZO6 maf
expensive:
-roller rockers
-long tube headers w/ dual electric cutouts
Old May 16, 2003 | 02:26 PM
95TA8280's Avatar
Originally posted by teke184
inexpensive mods:
-pullies
-airfoil
-ZO6 maf
expensive:
-roller rockers
I dunno how much those (inexpensive) mods will help......besides the cutout and water pump, the other ones are good for like 5 HP total, I believe.....
A cutout would be a good idea, and it's around $50 including the weld. If you got the loot, headers would really open that exhaust up. The free mods would also be good.
Old May 16, 2003 | 02:29 PM
hairbear21's Avatar
You didn't mention whether or not you have a K&N Cold Air Induction kit or just the panel filter. If I were you, I would get the entire CAI, and also do the TB bypass
Old May 16, 2003 | 02:33 PM
Bastardcat's Avatar
Headers
Old May 16, 2003 | 02:39 PM
Derrick Redd's Avatar
NX kit, 3,000 stall, cutout. Oh, and ET Streets for some kind of traction.
Question
I don't have the K&N FIPK, just the standard air filter.
About headers, what do you guys like?
Also, what all is required to install them?
Old May 16, 2003 | 02:42 PM
Bastardcat's Avatar
Then you may want to go with a CAI like K&N, SLP, Morosso, they're all about the same.
Old May 16, 2003 | 02:45 PM
Buttercup's Avatar
Good cat-back exhaust before hassling with headers. If you can handle the noise a cutout is plenty effective and cheap.
A full CAI is also one of the first mods to do!
TB bypass is free and easy.
Always start with the easy air-in/air-out stuff before diving into expensive parts and headaches.
As always I will say "leave the MAF alone!"
Electric waterpump isn't for everybody. If you don't mind the fact that it can fail anytime than go right ahead but most of us use these pumps to run stronger timing sets with our cam setups, a few extra hp is an added benefit.
Depending on miles you may want to invest in a good tune-up!
Old May 16, 2003 | 03:09 PM
BOWTYDE's Avatar
Headers with high flow/off road cats
Old May 16, 2003 | 03:27 PM
Buttercup's Avatar
Why is everyone saying headers He doesn't even have a cat-back!
Old May 16, 2003 | 03:38 PM
96ZRDR's Avatar
Forget about the cat-back......for now it will only give you minimal gains, headers will really wake up an LT1. The $300+ for a catback can be used for some decent headers....
Hooker Lt's if you have no emission requirements
or either MAC's, or Hooker shorties will be good.
I wouldn't condiser a Flowmaster muffler much of a mod, you need to increase the size of those pipes or invest on a custom dual exhaust set-up. Now you are rolling.
CAI is a must.....!!!!!!!!!!!
Then gears
Old May 16, 2003 | 04:00 PM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
What ever you do, leave the MAF alone. What a waist of money. I'm still running my stock one on my solid roller.
I'd do headers and Exhaust.
Old May 16, 2003 | 04:02 PM
Buttercup's Avatar
You'd advocate running hooker longtubes through the stock exhaust and a flowmaster?
A cat-back gives about as minimal gains as a CAI, by your logic you should forget about the CAI as well and dive right into a monster cam and heads.
Or, maybe I'm the crazy one
