SPEC problem?
Old May 15, 2003 | 01:15 AM
Lester 94-Z28's Avatar
SPEC problem?
Basically, my old SPEC stage 3 carbon went out, replaced it with the same thing. Now when i depress the clutch a bout 65% down, the fork begins to grind on the pressure plate. Im wondering if anyone has had a problem like this. Was this clutch installed improperly? Or maybe I was possibly given the wrong model. What I am thinkning is the pressure plate is too thick and sticks out too much and makes contact with the fork. Any thoughts?
Old May 15, 2003 | 05:10 AM
Zeueses 97 RamAir's Avatar
bent
who ever put it on knows the way it fit if it was wrong, i say your fork is bent get a aftermarket fork...
Old May 15, 2003 | 07:26 AM
firepheasent's Avatar
There is only one way the fork should slide on. The neck off the bearing is shape like a rain drop and the fork should slide onto and arround the pointy side of it.
Jason Coffman
Old May 15, 2003 | 02:55 PM
a bent fork is an interesting thought. i'm gonna call SPEC and see what they say. Thanks for the input.
Old May 15, 2003 | 04:09 PM
FireAm94's Avatar
How long did the first SPEC last? I will probably be buying one soon.
Thanx
Joe
a long time, great clutch
Old May 15, 2003 | 11:26 PM
Old May 16, 2003 | 12:40 AM
hsyr's Avatar
Sounds exactly like what happened to me! A spring blew out of my clutch disk thanx to a worn out pilot bushing. We took the clutch out and the spring fell to the floor. So we put a new disk in and put the car back together. What happens, the symptoms you describe are pretty much the same except it was very hard for me to shift gears or get it in gear. Took it apart again and I found the small spring that was inside the big spring in the clutch disk was wedged in the PP somewhere so it wouldn't allow it to disengage. Play with your fork more if that doesn't work pull the tranny
Oh btw mine is a SPEC stage III ceramic.
Old May 16, 2003 | 09:55 AM
FireAm94's Avatar
So you used a bushing instead of a bearing?
Joe
grabbem88
Mar 25, 2015 12:09 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Ws6Envy
Mar 3, 2015 04:31 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
nophix
Nov 30, 2014 10:26 PM
