electric water pump question
Old May 16, 2003 | 05:40 PM
MellowZ's Avatar
Question electric water pump question
Hi all,
I'm new to the board so let me extend a big howdy.
My stock water pump's weep hole is crying up a river. I'm thinking since I have to buy a new one I might as well get a CSI electric pump. But I did a search and looked at the install instructions on the web, and it looks like that swap retains many of the stock mechanical WP's internal parts. Will upgrading to a CSI actually fix the weep hole condition? If not I guess I'll probably get a remanufactured mechanical WP at Kragen...
Thanks in advance for the help.
Old May 16, 2003 | 05:45 PM
Buttercup's Avatar
It only reuses the stock housing. The moving parts are removed, you essentially gut the stock housing and bolt the electric pump into it.
When you install the electric pump you will plug the weephole so it definately shouldn't leak.
Are you sure you want to go this route? While it won't leak, there's a good chance it will fail on you when you are far from home The only reason I run one is so I could run a heavier timing set. I live with it just fine but I know the day will come when it fails, hopefully I'm close to home
Old May 17, 2003 | 03:05 AM
MellowZ's Avatar
Hmm...actually now that you mention it that 5500 hour life span sounds a little weak...that's less than 5000 miles...methinks this mod money might be best spent elsewhere...
Old May 17, 2003 | 03:12 AM
Zepher's Avatar
How do you figure it's only 5000 miles?
5500 hours equates to 330,000 miles, at 60 miles/hour.
Old May 17, 2003 | 10:19 AM
Lunarson's Avatar
maybe he drives really really slow eh? Just kidding Mellow, it should last for a good long time before it needs replacing and furthermore for the price you could carry a spare and possibly change one on the side of the road as well, its not nearly as involved to change an electric as it is a stock pump.
Old May 17, 2003 | 10:45 AM
Buttercup's Avatar
There's been lots of pumps that have failed well before their rated liftetime, fwiw.
I hope my CSI goes as long as it's supposed to but being an electric pump, I won't be shocked if it fails a bit early.
Old May 17, 2003 | 11:01 AM
MellowZ's Avatar
Yeah I confused hours and minutes...I heard there's a difference. I should know better than to do math at night.
Old May 17, 2003 | 05:58 PM
Zepher's Avatar
Yeah, after I posted that, I checked it about 5 times since it sounded kinda high and I didn't want to look like a dumbass.
HectorM52
Jul 30, 2017 11:46 AM
BMX Dad
Jan 23, 2015 07:00 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
