motor mount install?
Old May 16, 2003 | 06:30 PM
mineralwater's Avatar
What's needed for a motor mount install? I know that I have to get the car on jackstands, and then lift the motor by the oil pan with a jack at least an inch or two..
from there on, what do i need? Will a basic socket set with extensions suffice? I've never changed motor mounts, hell, I don't even know what they really look like.. but I got them coming today and I have to install it on saturday.
any tips, help, suggestions, would be greatly appreciated! pictures and diagrams, if anyone has some, would really help..
Old May 16, 2003 | 06:55 PM
wantafastz28's Avatar
For me swapping motor mounts was a nightmare. What i ended up using is about 3 feet of extensions to get the passenger side from the top along with a couple of swivel joints. Besides that the only thing that will really help ya is some skinny arms. Goodluck.
Mike
Old May 16, 2003 | 07:54 PM
meangreen95z28's Avatar
You will also need a drill to drill out the rivets in the "clam shell".
Old May 16, 2003 | 11:29 PM
doh! how powerful does the drill have to be? I have a ryobi electric drill, but i don't know how powerful it is.... hmm.
well i guess i'll figure it out. thanks for the tips guys.
(also, one motor mount is smaller than the other.. which goes to which side?)
Old May 17, 2003 | 01:43 AM
96speed's Avatar
Its very straigthforward. Having two people is a real treat because you'll need to jack the motor up just enough to release the pressure on the motor mount thru-bolt. You'll see what I mean when you start working on them.
Do one at a time.
For the passenger side you might need to pull the steering linkage - Makes thing easier.
Good luck. You'll start pulling the motor mounts for other installs once you realize how easy it is. However, the first time it wasn't fun .
Good luck!
Ryan
Old May 17, 2003 | 04:09 AM
thanks for the replices, everyone!
The most i've done on my car was the cam and 1.6rr install.. and that was pretty straightforward since I had a good idea of what I was removing and installing..
but I don't even know what the motor mounts look like, so I'm a bit nervous, to say the least.
Hopefully I can get it all done by tomorrow night. Thanks again, guys!
HectorM52
Jul 30, 2017 11:46 AM
Richardan15
May 30, 2015 08:36 AM
Jason Short
Jan 19, 2015 06:34 PM
