*Urgent* How do I break loose the flywheel bolts?
Guest
Posts: n/a
I managed to get a breaker bar on there and had a friend hold the flywheel so it wouldn't move. It would move slightly but the bolts finally budged off.
Anothe method is to have a friend hold a wrench to the crank pulley so as to keep the flywheel from moving.. then getting the flywheel bolts off that way.
There is a tool you can buy specifically for this purpose. It's pretty cheap and looks like a big screwdriver with an arm attach near the bottom. You hook it on a tooth on the ring gear and then stick the screwdriver tip into another tooth and then it becomes a handle to turn the flywheel or just hold it in place to tighten or loosen.
The other thing you can try is to turn the flywheel so the bolt you are loosening is on the other side from where you are trying to turn it from. This will give you more leverage on the bolt, but not on the crank because you're pushing back across the lower part of the flywheel compared to the bolt.
Good luck,
-Dave C. '97 Z28
Good luck,
-Dave C. '97 Z28
Well I got the flywheel to stay put but now the bolts are so tight that I still can't get them loose. Im off to go buy a big breaker bar but still, the the 12pt. socket I have was starting to slip and round the bolts slightly. So I dont know if its gonna help or not but I guess we'll see.
Aaron
Aaron
no they are not reverse threaded...i did what was said earlier, get the bolt u want to loosen at the top of the flywheel (by turning engine) and put an end wrench on it vertically coming down...and just go at the wrench with a hammer..this gives u leverage on the bolt, but not on the flywheel
Aaron
Aaron
Use a rag wedged between the flywheel and the housing to keep the flywheel from turning.
Re: *Urgent* How do I break loose the flywheel bolts?
Air tools work great, lol. got those flywheel bolts off in 1 zzzzzzzup 2 zzzzzzzzup 3 zzzzzzzzup 4 zzzzzzzup 5 zzzzzzzzzzup. how ever long it takes you to read that.
Victor Lamb
Aug 26, 2017 02:52 PM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
