Subframe Connecter install Question
I'm going to install a pair of SLP weld ins this weekend. Should the car be on a wheel lift or a chassis lift for the install? I've heard and seen it done both ways. Which one is correct?
this is taken directly from BMR's website;
Jack up the car and place 2 jack stands under the rear inner frame rails (rails that run next to fuel filter)and two under the front A-arms. If possible, it is preferable to place the front tires on ramps. Jack up the rearend until the lower control arms are close to parallel with the ground and leave the rearend supported with the jack.. DO NOT SUPPORT BY REAREND ONLY! If using a lift, disregard this step and move on to step 2.
Remove front bolts on the lower control arms. The rearend may shift slightly rearward.
Position the subframe connector over the rear control arm mount so that it "sandwiches" the subframe. Using the provided hardware, slide bolts through subframe connector, subframe, and control arm and install nut finger tight. Repeat this step for the other side.
Lift the front of the subframe connector up until the front mounting plates are flush with the subframes. On 1993-1997 cars, it is necessary to remove the plastic fuel line clip (shown in Image 1 below) in order to allow the subframe connector to sit flush with the frame rail. Hold into position and use a marker to mark the subframes in all weld areas. Lower the subframe connectors ans remove paint from the subframe and the subframe connectors at the weld points using a wire wheel or sander to get bare metal. Re-position the subframe connector in place and weld a bead around all three sides of the front mounting plates and all three sides of the rear mounting plates (See images 2-3 for weld areas).
Once both sides are welded, lower the vehicle to ride height and tighten the rear control arm mounts making sure that it compresses the bushing.
DEFINITELY put it on a wheel lift so that the entire car is under a load. I have seen people do it on a chassis lift and it has cause severe twisting of the SFC when the car is back on the ground.
07-04-2005 05:00 PM
