Rear question(is this normal)
Old May 16, 2003 | 05:59 AM
johnpsz's Avatar
had my tires replaced the other day and when the guy was doing the alignment, He rotated the rear tires. By rotated I mean he spun them around checking the calibration of the machine. I was standing there watching this and as he rotated the driver side rear tire the passenger sided rotated at the same speed and everything like they were linked with a spool or something.
I thought that was a little strange and when he did the pas. side the same thing happened In other cars I've had if you have the rear end off the ground and spin one side the other normally goes in the other direction?
What is normal all the cars I've had that have done this (rotated opposite directions) were limited slip cars, 2 mustangs, and another 95 formula I had with 3.42's. Could the rear be locked together? Or, is this normal?
Old May 16, 2003 | 06:52 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
if it spins it the opposite direction... launching would be intresting.
unless there is something different about it when its in air that i dont know about, i dont see why it would spin the other way...
then again- my best friends dad has always dont all the work on my rear so i'm not 100% sure about this...
i know that when i spin my driveshaft both go the same way...
Old May 16, 2003 | 07:22 AM
akrott1's Avatar
If you spin the driveshaft they should spin the same way.....obviously that simulates what the engine does....
however, if you have it in gear and raised off the ground, when you spin one tire, it should spin the tire in the opposite direction. I believe since yours did not that could mean that your posi clutches are worn out.
Maybe some real experts will pop in here and give you some better info.
Old May 16, 2003 | 07:48 AM
treyZ28's Avatar
for some reason, there was an inling inside me to say there would be a differance when you spin the wheel and not the DS, but i couldn't rationatize why in my head...
perhaps a expert could also explain why
Old May 18, 2003 | 09:21 PM
johnpsz's Avatar
Everything seems to be working fine. I just always feel like it is always running a posi. Around turns with any type of pressure on the gas pedal, I get the squeal that that comes from a spool on street tires, but if of the gas completely it will sometimes act as if it is unlocked.
Old May 18, 2003 | 10:22 PM
cridom's Avatar
posi track= noth wheels turn the same
limited slip= different directions
Old May 18, 2003 | 11:48 PM
ScottZ's Avatar
only an open carrier (no posi, locker, spool) will allow the tires to spin in opposite directions with no load. Your car is normal. A car with a posi will spin both tires off the ground. That's the point of the posi. The clutch packs are creating friction to prevent differential action. Only if they are worn out (really badly) will the tires spin in opposite directions.
Don't worry, your rear end is fine (in the car).
Scott
Jan 13, 2015 09:52 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
pete53
Dec 9, 2014 07:31 AM
jayblev95
Dec 1, 2014 06:55 AM
FiNSTa
Jul 20, 2002 10:57 PM
