how long to expect for waterpump install?
well guys it looks like my waterpump is finally done...I would really like to replace it with a mezeire or CSI, but I need the car everyday for work and school. How long should it take me to change the wp? I dont have extensive knowledge, but I have changed several things such as the radiator, plugs, etc. so I think I can do it...Just was wondering about a time estimate.
Does the lt1 still have the standard small block chevy style water pump? The 4 bolt ones?
Those are cake to change. I can change a waterpump in my 88 in 15 minutes probably...
I can install headers on mine in 1 hour tops...im sure most lt1 guys cant say that.
took me all day first time
second time it took about as long
third time i had the thing on ramps, drained, waterpump off, run up to parts store, take lunch breaks, waterpump back on, and then taking tset runs down the street in 4 hours
The lt1 waterpumps have 6 bolts. Just make sure you get it wired right. I did a headgasket change and CSI pump in about 6 hrs. But you don't have to do the heads so I'ld say about 2hrs. Depends on how you wire it. (wether or not you want a switch or indicator light on your dash)
Sergio
Jan 27, 2016 04:27 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
