vette servo
Old May 16, 2003 | 03:13 PM
rage366's Avatar
vette servo
will putting a vette servo in a 4l60e help it shift more easily into OD? the problem is that the car shifts fine into 1st 2nd 3rd, but it has trouble shifting into OD.
thanks.
Old May 16, 2003 | 07:37 PM
12SCNDZ's Avatar
Your car already has a Vette servo. Most factory 700/4L60E transmissions shift into 4th pretty lazy. Sonnax makes a large diameter 4th servo that will help the shift quality. As a side benefit, it also adds holding power, which will help the 2-4 band life.
When I build performance 700/4L60E's, I also block the 4th accumulator piston in the case, which helps firm up the 3-4 shift.
Frank
Old May 16, 2003 | 07:50 PM
94FlamdS10Blazr's Avatar
you can get an overdrive servo as well as your regular corvette servo. I did both in my Blazer 4L60E build up
Old May 17, 2003 | 07:09 AM
rage366's Avatar
hmmm, do u have a specific brand name? model?
thanks
Old May 17, 2003 | 08:06 AM
I got mine from www.kdsperformance.com really coool guys to deal with and they will talk you threw it all
Mikes 1994 z28
Oct 10, 2015 07:55 AM
lil305gta
3rd Gen / L98 Engine Tech
Aug 16, 2002 07:20 AM
lil305gta
Aug 12, 2002 07:58 AM
IROCKER
Aug 9, 2002 08:54 AM
lil305gta
Aug 8, 2002 03:08 AM
