High volume oil pump question(Do you remove the top of the pump to change the spring)
Old May 16, 2003 | 06:07 PM
Rpm280's Avatar
I have a high volume, high pressure oil pump , and I just want to change the spring to lower the pressure . A lower pressure spring came with the pump. Do I just take the top of the pump off (remove the 4 bolts) to do this?
Thanks.
Old May 16, 2003 | 06:14 PM
97 RedSS's Avatar
I believe its just a pin that holds the spring in there..just remove the pin, change spring, and reinsert the pin..
Cody
Old May 16, 2003 | 07:21 PM
Rpm280's Avatar
Cody
I saw the pin, but how would you get it out?
Old May 16, 2003 | 07:39 PM
I burn rice too's Avatar
Yes, you do have to have to remove the top to get to the spring pin. No big deal.
Old May 16, 2003 | 10:56 PM
Rpm280's Avatar
[i][/B]
Thanks.
ANDYZ28
Dec 29, 2014 09:13 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
