How can I find out which gears I have?
Ok, I have been tryin' to figure out what gears I have in my 93 Z. It is a A4, but I thought that read someone where on here, that if I can shift into first gear that it was 3.23's is this correct? Because I can shift into first gear, there is no stopper stopping it from going into first gear. Any help would be greatly appreciated. Thanks in advance for all who reply.
Tuff.
Tuff.
If your console shows a spot for first gear, you've got 3.23s, if it starts at second gear, it's 2.73s. Also check your glovebox for the codes, if you see GU2 it's 2.73s, if you see GU5 it's 3.23s.
Tuff.
only for sure way is to jack the car up and turn the rear wheel and watch how many times the driveshaft turns. put the car in neutral first of course.
if it turns a little over 4 then you have 4.10/4.11, turns almost 3 times, you have 2.73s, etc
Ok, I just check the codes in the glove box and in the codes was a GU5, so is that 3.23's? Or should I jack the car up and check how many times the drive shaft turns? Thanks again
Tuff.
Tuff.
Originally posted by thewinner
i would jack the car up, unless you are the original owner or know for sure the gears havent been swapped.
Tuff.
Tuff.
Tuff.
Next time you are under the car you can check it, but there is really no reason to crawl under there if you are just curious.
It's a pretty safe bet that you have 3.32's
Jul 4, 2005 05:00 PM
1LEThumper
Jul 14, 2003 12:45 PM
