Help with clutch problem…
Old May 16, 2003 | 11:50 AM
aozame's Avatar
Question Help with clutch problem…
I just installed a new SPEC Stage 3 Carbon clutch to replace a toasted Stage 3 Kevlar in my ’94 Z28. The installation went well but I seem to have bad chatter engaging 1st gear from either a stop or slight roll. Hill starts are impossible -the whole car shakes. I’ve tried varying the amount of slippage and rpm when starting off, but I can’t seem to get a smooth engagement. Shifting between the other gears once underway is smooth, and the clutch is not slipping.
Is the clutch grabbing too soon as it is not properly broken-in? It appears that it just grabs and then bogs the engine to the point of stalling resulting in shuddering. Is this normal?
What is the break-in procedure for this clutch?
Can anything be adjusted to eliminate the engagement chatter?
Thanks!
Old May 19, 2003 | 12:58 AM
fbird95's Avatar
I had the same problem with my clutch. It wasnt a spec stage II though. New clutches tend to be picky. They can sometimes be like a light switch, Off or ON. They either slip or catch there is no inbetween point. They slip or grab, with no medium, causing the driver to look like its there first time driving stick as the whole car shakes. Mine was real bad. Heres what i did, Launched the car a couple times hard holding it inplace letting the clutch slip, and a few hard down shifts on the highway. It straghtened the problem right out. I'm not sure if this is the same break in for your car, but it worked for me.
As for the chatter, its fairly common especially with the Spec Stage III. Does your Throw out bearing make anuy kind of noise after the install?
Old May 19, 2003 | 02:41 AM
IllusionalTA's Avatar
Just the nature of the clutch.. .. not a problem.. i have had 2 kevlar's ,a ceramic and a carbon..the last 2 chattered pretty bad.. till they exploded anyway.
Old May 20, 2003 | 12:17 AM
aozame's Avatar
yeah, this makes sense. it appears to be getting a better with a few hundred km's on it now. thanks! boy does this thing bite!
BigWil
Mar 29, 2015 12:24 PM
BPS
9
Mar 5, 2015 10:51 PM
eazyZ
Mar 1, 2015 07:12 AM
HectorM52
Jan 30, 2015 11:08 PM
siguy
Nov 27, 2014 10:07 AM
