careless mistake, need firing order of opti
Old May 16, 2003 | 05:52 PM
ChvyCruzen's Avatar
I was fustrated with my car and made a careless mistake. I pulled off the spark plug wires from the opti without labeling which is which. I need a diagram showing the firing order or can someone tell me how it fires from top to bottom on left and right side?
Thanks!
PS, im fustrated because the rod broke in my 94 LT1......
Old May 16, 2003 | 05:54 PM
Here is the info you need
Old May 16, 2003 | 05:56 PM
ChvyCruzen's Avatar
Thanks shoebox
djs_ta's Avatar
opti
I can't help you with the firing order but if you you look at the stock wiring loom it should go in the order they are in. The wire that is on the top goes to the connection on the opti. I did my opti last week and did not label the looms. If it is the stock wires and looms you should be set as long as no one rearranged the order of your wires.
Old May 16, 2003 | 06:03 PM
LWillmann's Avatar
My opti is clearly marked as to which wire goes where... It has raised numbers on it, if yours does, you can use a white crayon to highlite the numbers really well.
Sergio
Jan 27, 2016 04:27 PM
grabbem88
Mar 18, 2015 01:25 PM
