Need some help!!!! Timing Chain Cover Questions
Old May 16, 2003 | 05:41 PM
CamaroSS30th's Avatar
What is the difference between the LT4 Timing Chain Cover and a 97 Timing Chain Cover??? I ordered the LT4 Timing chain cover from TByrne Motorsports and got it today and it looks the same as a 96+ cover... I thought the LT4 cover was Composit piece like the LT4 Valve Covers? Any Help would be great...
Thanks,
Jay
Old May 16, 2003 | 05:59 PM
Never have heard about the LT4 timing cover being different.
Old May 16, 2003 | 06:07 PM
Dave Feerst's Avatar
Going off of memory here, so somone correct me if im wrong.
There are 3 different timing covers on 93 -97 F-bodies
The first one had a small center hole for the spline drive opti
The second one which ended in 95 or 96 was had a larger cam hole for the pin drive opti
While these cars were being produced they made the LT-4 which had a crank sensor and therefore a different timing cover,
And then sometime in 96 or 97 the gave the F-bodies the crank sensor as well. And I think the 97+ or and model with a crank sensor has the same cover as the LT-4.
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
