lt1 block casting number?
Old May 14, 2003 | 10:48 PM
redemn93's Avatar
does anyone know it? i friend of mine just bought an 81 camaro z28. the guy he bought it from claims the previous owner put an lt1 in it. i cant tell if it since its carburated and has a clutch fan. it does have aluminum heads though. if its not an lt1 i hope its a zz4. they have aluminum heads right?
Old May 14, 2003 | 11:31 PM
An LT1 has "327" cast in all sides of the block and is easily distinguished by the cam driven, reverse flow water pump that has 6 mounting bolts.
Old May 14, 2003 | 11:33 PM
redemn93's Avatar
i believe i noticed it being cam driven. i have to look though. ill count the bolts when i see the car again. so you mean "327 is stamped on it?
Old May 14, 2003 | 11:41 PM
You can see the inverted casting here by the knock sensor. It is also on the other side of the block and on the front .
Old May 14, 2003 | 11:44 PM
redemn93's Avatar
sweet deal. now i can find out. thanks alot
F'n1996Z28SS
Aug 23, 2023 11:19 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
FryZss
Sep 3, 2002 03:52 PM
