waterpump won't come off..
Old May 16, 2003 | 11:37 AM
blak96SS's Avatar
ok, bear with me here as this is the first time I have ever done this...I thought I had all the bolts out of the waterpump, but it seems like its not going to come off at all. After looking, it seems as though I only have 5 bolts (4 long ones and a shorter one) but I have been looking and I dont see the 6th bolt I am supposed to remove. I know this is a tough question, but can anybody give me a little help as to where I am going wrong?? TIA.
Old May 16, 2003 | 11:44 AM
Compstall's Avatar
There ARE 6 bolts that hold on the water pump. 3 on each side. Look around,you'll find it. They're in the same location on each side.
- Brent
rocmemphis's Avatar
There are 6 bolts...3 on the left and 3 on the right. Look real good...one on the left side is kind of hard to see.
Old May 16, 2003 | 11:58 AM
z28jaz's Avatar
you probably missed the bottom bolt on the drivers side. It's also a bracket for the air pump. You have to take the nut off, then remove the pump, then you can take the bolt off.
Old May 16, 2003 | 12:00 PM
94 CAMRO Z28's Avatar
What he said, I missed this the first time around too.
Aaron
Old May 16, 2003 | 12:08 PM
Rich97 W68's Avatar
Eternal Member
Bobby!
Ya shoulda waited for me ****!!!!!!! Good luck. Call me if you need help...
(Yahoo: "darth_jeebus")
Old May 16, 2003 | 12:12 PM
...or you missed the one that is slightly hidden by the p/s pump pulley...
anasazi's Avatar
don't forget about the one behind the power steering pully! that one is a huge PITA but you can get it out without removing anything... just takes the right extensions and lots of patience.
Old May 16, 2003 | 12:28 PM
blak96SS's Avatar
ok, i missed the one hidden by the air pump bracket...the problem is I cant get one of the bolts off the bracket to get to the last bolt for the waterpump...its the 9/16'' bolt that is kind of recessed that is giving me problems...I dont know how I am going to get it off..Thanks guys.
Old May 16, 2003 | 12:35 PM
Should not be hard. Remove the AIR pump first to get to the bracket.
Old May 16, 2003 | 12:37 PM
blak96SS's Avatar
i can get to the bolt, i just cant seem to break it loose...thats the problem. I cant get any leverage on it to force it off. I guess I'll just keep tryin..
Old May 16, 2003 | 12:40 PM
anasazi's Avatar
lefty lucy righty tighty
Old May 16, 2003 | 01:21 PM
blak96SS's Avatar
Originally posted by Rich97 W68
Bobby!
hey Rich, Im gonna be finishing it up tomorrow morning if you can help...Check FA for details..
Old May 16, 2003 | 02:17 PM
thewinner's Avatar
socket + ratchet + 4 ft piece of pipe. Works wonders, especially for breaking head bolts loose.
68camaroboltz
Oct 5, 2015 01:46 PM
Hal Fisher
Sep 30, 2015 09:03 PM
KYWes
Sep 26, 2015 08:49 AM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
