Pass Cyl Head not coming "right off"
Old May 15, 2003 | 09:00 PM
94_Z28_guy's Avatar
I can rotate the cylinder head about 15 degreess up and to the left (facing car) but then something is stopping it.
I have the PS pump off, and two of the bracket bolts off that screw into the head. I did not take the bracket off.
It looks like the one bracket hole is flanged out and fits into the side of the head, this might be what is stopping it. (?)
Anyone done this and can think of what might be stopping it. I am not going to force it. Should it lift straight up? I know there are studs, but I don't think that is it.
Thanks in advance.
Old May 15, 2003 | 09:32 PM
97 RedSS's Avatar
Sounds to me like its just stuck onto the bracket..I would take a flat-head screwdriver and a rubber mallet and lightly tap in between the head and bracket and it should seperate them..Make sure you got all 17 head bolts out also
Cody
Old May 15, 2003 | 09:41 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Cody
yeah, i thought there were 17 there- miscounted and broke a head bolt
Old May 15, 2003 | 10:04 PM
94_Z28_guy's Avatar
Thanks,
Yeah - I double checked the bolts like three times
I was going to try the screwdriver thing, but wanted to check first. Still seems like the back end should come up first, then the front, but oh well.
Old May 15, 2003 | 10:41 PM
Draco's Avatar
This might be a stupid question but did you take off the steam line connecting the two heads at the back?
Old May 15, 2003 | 11:40 PM
slashz28's Avatar
i was thinking the same thing??
Old May 16, 2003 | 12:57 AM
Formula_one's Avatar
w3rd
Old May 16, 2003 | 01:15 AM
94 CAMRO Z28's Avatar
You dont have to take off the steam line. I left mine on and pulled the heads as a pair.
Aaron
Old May 16, 2003 | 07:10 AM
94_Z28_guy's Avatar
Thanks, but yes. I took off the driver's side first, which came right off. This head is loose, just won't come off. I'll try again after work.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
MadMav
Feb 6, 2015 11:02 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
