Powersteering pump.
Powersteering pump.
I need some help. When you remove the two bolts holding the P.S. pump on the big bracket, do you have to unhook either liquid line to the pump to remove the large bracket from the engine compartment when pulling engine out the top. I thought I could just let P.S.pump and A.C. compressor stay in the engine compartment off to pass. side while changing the engine. Is this ok to do? Thanks.
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
